Got a Virus when downloading Plugin effect loop ot 2.1 TWICE
geposted Wed 30 Mar 11 @ 7:07 pm
False positive.
geposted Thu 31 Mar 11 @ 5:20 am
SBDJ wrote :
False positive.
Whaaaaaaaaat......... Do you mean it's not a virus, but just says it is?
geposted Thu 31 Mar 11 @ 2:52 pm
That's true. It happens with Norton mainly. Read more inputs here https://virtualdj.com/forums/136724/VirtualDJ_Plugins/Virus_in_VDJ_download__Using_Norton_.html
geposted Thu 31 Mar 11 @ 3:10 pm
you gotta pop up twice ....not a virus
virus engine database didn't recognize the file ...since it is an unknown .exe it
issued a warning
issued a warning
geposted Thu 31 Mar 11 @ 4:31 pm
I agree 100% the following 4 files are infected by Suspicious.Mystic maleware:
Date & Time,Risk,Activity,Status,Recommended Action,Path - Filename
2011-12-02 08:49:17,High,a0151339.exe (Suspicious.Mystic) detected by Virus scanner ,Quarantined,Resolved
2011-12-02 07:33:02,High,a0151338.exe (Suspicious.Mystic) detected by Virus scanner ,Quarantined,Resolved
2011-11-28 23:09:35,High,install_flanged_loopout.exe (Suspicious.Mystic) detected by Virus scanner,Quarantined,Resolved
2011-11-28 23:09:03,High,install_32-band_equaliser.exe (Suspicious.Mystic) detected by Virus scanner,Quarantined,Resolved
geposted Tue 27 Dec 11 @ 6:36 pm
Did you solved your "false positive" virus with antivirus softwares ? I would know before trying to try to test this software again. (I know it's a thread from 2011 but i got this problem last year)
geposted Wed 21 Nov 18 @ 8:18 pm
Please don’t dig up old threads.
I don’t recall seeing anything recent about false positives on these forums (although I may have missed it). Why don’t you try installing and post something if you have a problem? In a new thread that is.
Given that VDJ is installed around the world all the time, I think we would have heard something if it happened recently.
geposted Wed 21 Nov 18 @ 8:29 pm
send me the links to them 4 and I will install them on one of my older laptops and see what happens,
I have had a few false positives when downloading the old add on`s. from one or two visualisations
i installed them anyway with no issues after installing, Its just an alert because it does not know what it is that its installing so it treats it as suspicious
geposted Sat 24 Nov 18 @ 3:54 am
