I'm in a difficult situation because I'm either going to buy the RMX or the Mix track Pro they both have VDJ LE and both have built in sound cards and the Mix track is cheaper buy quite a bit my budget isn't very high either so other suggestions won't be to helpful.
Question
Which is better
are there any faults with either of them
Do you recommend the mix track
is the Mix track as advance as the RMX and would last me along time (3 years at least)
Question
Which is better
geposted Thu 31 Mar 11 @ 3:07 pm
just found that the mixtrack le only comes in north / south america is this true
geposted Thu 31 Mar 11 @ 3:08 pm
Whats up, Im going with the Mixtrack Pro, it has a built in sound card etc, and yes I know it includes LE but not sure if its available anywhere besides north/south america.
- Hallabackkid
- Hallabackkid
geposted Thu 31 Mar 11 @ 3:10 pm
I Had A Dac-2 And I Also Have 2 Dac-3, And Now A RMX,But If I Had To Do It All Over It Wood Have Been The RMX,I Wood Have Got 2 RMX.The Sound Is Unreal With RMX And It Look More Like A Real Dj Tool.
geposted Thu 31 Mar 11 @ 5:31 pm
Hej babe,
I agree, i have an RMX and its really good, has a great sound and is more... substantial and looks like a proper bit ov kit.
But once your used to it then get VDJ Pro software as its more stable, more versitile and you can get extra skins for the display on ya computer.
Hope that helps some
XXXSeanaXXX
XXXSeanaXXX
geposted Thu 31 Mar 11 @ 5:51 pm
If you plan to scratch, then get either Mixtrack pro or the Hercules 4-mx! If not, get the Hercules RMX! I have the RMX and people can say what they want about it, but it is by far one of the best consoles out there. I find it even better than some of the so called newer consoles. Plus the sound is sweet!
If you're on a budget, then either one of these 3 will work, because they range from $200 - $500 US dollars. If you got to save up for it, then do so, because if you plan to be a DJ, this is a start to understanding the hustle and grind section of being a DJ.
Best Wishes,
DJ Coach K aka THE MIX MONSTER
Best Wishes,
geposted Thu 31 Mar 11 @ 6:38 pm
I've had my rmx for 3 months now. Love it. It is well built, fully programable, and I can't keep my hands off of it lol. I would not reccomend it if u plan on scratching a lot, but if not, pick this up!
geposted Fri 01 Apr 11 @ 12:46 am
i feel that the RMX is strong on features and build , but not on the soundcard
my other external soundcard is the M-Audio fast track ultra and it blows away the RMX
of course the ultra is a dedicated , expensive , stand alone .....
also you give away your age when you call it a soundcard ......
"it's an interface " will remove years of lines and wrinkles from your appearance
and you will get laid more .....
geposted Fri 01 Apr 11 @ 1:06 pm
