Hello need some help I just bought a Hercules dj console Rmx and was going to upgrade the software since home free will only work 10mins with the hardware. It says I need pro. when I put my product key in to upgrade the only choice is full pro. will pro basic work for my RMX?? thanks in advance.
geposted Thu 31 Mar 11 @ 5:14 pm
never mind I just read on the list that only full pro works
geposted Thu 31 Mar 11 @ 5:21 pm
you should have got vdj LE with the rmx, which will let you use the console, but some features will be limited such as the timecode option (i think it is 10 mins).
if you upgrade to pro, you get all the extra services and options of vdj to you. so yes it will, you just need to have the drivers for rmx and your good to go
geposted Thu 31 Mar 11 @ 5:28 pm
Please register your Virtual LE version of your RMX here https://virtualdj.com/users/edit.html
It will give you a significant discount if you decide to upgrade to Full version.
geposted Thu 31 Mar 11 @ 5:35 pm
