I'm looking for a delay effect that'll run after the song stops. I'm using a mac, so my options are a little limited, but any ideas? Everything I've downloaded stops as soon as I hit PAUSE. I can get the effect by setting loop points and manually fading out...but was wondering if there's an effect for MAC that would work?
geposted Thu 31 Mar 11 @ 9:31 pm
Try this, https://virtualdj.com/addons/12067/EchoDoppler.html
You'll have to play with it and try different things but it'll keep going when you press the pause button.
Hope that helps
Huey
Hope that helps
Huey
geposted Fri 01 Apr 11 @ 1:28 am
