Forum: Old versions
Topic: RMX mac book pro
can i put VDJ pro on Macbook pro, while i still have it on my Microsoft laptop?
geposted Fri 01 Apr 11 @ 7:02 am
The End User License Agreement (EULA) allows you to have the software installed on up to two computers at any one time, providing that they are both for your own personal use and will not be used simultaneously (E.g: Second installation as a backup or for practising at home is OK, allowing a friend or another DJ to use it is NOT allowed.)
You may also uninstall the software from an old computer and then install it onto a new computer.
NOTE: If you intend to sell, give away or dispose of an old computer, you must remove VirtualDJ from it first.
You can download the install file for the software again (If needed) from the Download Center: https://virtualdj.com/download/updates.html
i was ment to say as well. to use it with the RMX, but some how i forgot to write it in.
thanks guys, that is all
I believe you can install vdj7 and the rmx on a new computer. you just have to install the rmx drivers and vdj 7 and it should be good to go :)
