Hi im using VDJ pro7 on a mac and have just brought a machine for backup i know this is probebly a newbie question but cant find the answer by searching (probebly dosent help im dyslexic ) belive me im not a newbie but could anyone tell meif i have to purchase a new license to run VDJ on my back up machine or can i install on one more machine than my main like tractor allows 2 installs per licence
Thanks
Andi
Thanks
Andi
geposted Fri 01 Apr 11 @ 7:31 am
"[you may] install and use the Software on a second computer, if this computer is normally used by the same person and the Software will not be used on both computers at the same time."
https://virtualdj.com/atomixproductions/disclaimer.html
geposted Fri 01 Apr 11 @ 7:43 am
The End User License Agreement (EULA) allows you to have the software installed on up to two computers at any one time, providing that they are both for your own personal use and will not be used simultaneously (E.g: Second installation as a backup or for practising at home is OK, allowing a friend or another DJ to use it is NOT allowed.)
You may also uninstall the software from an old computer and then install it onto a new computer.
NOTE: If you intend to sell, give away or dispose of an old computer, you must remove VirtualDJ from it first.
You can download the install file for the software again (If needed) from the Download Center: https://virtualdj.com/download/updates.html
geposted Fri 01 Apr 11 @ 7:56 am
Thank you so much for your fast responces thats what i love about the VDJ forums
Andi
Andi
geposted Fri 01 Apr 11 @ 7:58 am
