Hi a novice no a compleate nob when it comes to pc yes :-) unfortunatly im a pc numpty as im a mac man couldent afford to have another mac book sat there as a back up just encase not being used so plumped for a pc laptop running windows 7 aparently a 64bit machine running VDJ 7.3 installed by hitting typicl install not custom i found out as i turned on and cme to install security software
question is on a pc how do you instll plugins like video effects i know on a mac i have to pop them in the relavent file and wallah there they are but on the pc i cant even find the relevent files i tryed the good ol double click methd on the plug in and the sound plugins went in but cant seem to get teh video plug ins in it says software not installed
hope you pc guys can forgive and help a mac man
Thanks
Andi
Thanks
Andi
geposted Fri 01 Apr 11 @ 11:29 am
You don't do something wrong. Plugins are automatically installed by executing the download file.
The latest version has a small bug in the installer and sets a faulty VDJ Home Folder.
There will be a fix in the next update but in the meantime, there is a solution here ...
https://virtualdj.com/forums/144671/General_Discussion/Skins__Effects__etc__saying_VirtualDJ_is_not_installed.html
geposted Fri 01 Apr 11 @ 12:45 pm
Thanks not come across because iv never had to use PC befor and started cursing and spitting at it like mac guy would will be on it like flin soon as i get back from this gig
thanks again for the fast respoce
Andi
Andi
geposted Fri 01 Apr 11 @ 1:47 pm
glad you cort me befor i got back from teh gig :-) ok like i said a compleat pc numpty how do i put that in as a batch file and where do i put that in or where do i edit the registry entry to put teh reg key in
thanks in advance for baring with me and being pc iliterate
Andi
Andi
geposted Fri 01 Apr 11 @ 8:06 pm
Just looked in regedit and my virtual dj folder is missing :-(
geposted Fri 01 Apr 11 @ 8:31 pm
You can copy and paste the text into notepad and save it to your desktop as vdj_homefolder_fix.bat - it is the .bat part which is important. It should then let you run it and create the necessary parts.
geposted Sat 02 Apr 11 @ 3:29 am
fantastic thanx i didi say im a pc numpty :-)
all solved now
and again thanks its time like this i realy apriciate the VDJ forums and the people that hang here
all solved now
geposted Sat 02 Apr 11 @ 8:12 am
