Forum: Old versions
Topic: Need help connecting Numark Mixtrack Pro with VDJ please
this is what i have
:Mixtrack Pro
:Headphones
:Desktop Computer with speakers
:Stereo 3.5 to 2 RCA
I can't get the music to play out of my speakers. I'm kinda new to this. hahah
geposted Fri 01 Apr 11 @ 10:03 pm
Make sure that you have plugged a pair of powered stereo speakers into the master outputs on the back of the console and your headphones into the headphone socket of the console.
Alternatively, connect a suitable cable (2x RCA to 3.5" headphone jack) from the master output of the console to the line input of your computer. The sound will then come out through the computer's speakers (If not, go to your sound card's mixer/control panel and ensure that the line input is not muted and the volume is set to an appropriate level.)
NOTE: VirtualDJ LE/Console Edition is free limited software and does not support outputting sound directly through your computer's own built-in sound card. It works with the sound card in the console only. For more flexible sound configuration options and much, much more, you will need to upgrade to the full VirtualDJ Pro: https://virtualdj.com/buy/
