Hopefully someone can give me some advice on this. I had a very odd issue come up last night.
Basically, I'm running a VMS4 with a brand new Macbook. Everything works like a dream now, but after about 6 hrs of playing, Deck 1 stopped having any output at all.
I did not change ANY settings on the controller, I tried multiple songs, everything looked right on VDJ...there just wasn't any sound. I switched to a backup, restarted the program and it worked perfectly again.
Any clues?
Any clues?
geposted Sat 02 Apr 11 @ 10:28 am
Sounds like a VMS4 Problem. Loosing connection.
geposted Sun 03 Apr 11 @ 7:16 pm
I beguin to have the same problem it was ok b4 now in the last party the left deck play but no sound coming up not even in the head phones
I have a vms4.1 windows 7 and vdj full pro 7
Any suggestions?
Any suggestions?
geposted Sat 23 Jun 12 @ 11:40 pm
Similar problem here with MacOS 10.7.4 and VDJ 7.0.5. Works like a charm for hours (sometimes only for minutes) with VMS4.1 and then suddenly a Deck isn´t working anymore, more likely Deck 1 but sometimes also Deck 2.
Also I´m experiencing that sometimes the Auto-Gain-Feature isn´t working correct. It just doesn´t raise the volume, so that that 1 track is just as half as loud as the other one.
geposted Tue 17 Jul 12 @ 1:46 am
