Is there a way to change the platter sensitivity when in scratch mode? Would that be in VDJ settings or in the Mixdeck menu itself?
Thanks in Advance.
Thanks in Advance.
geposted Sat 02 Apr 11 @ 12:33 pm
In the VDJ config menu, under options there is an adjustment called jog sensitivity. Try that.
Hope that helps.
AC
Hope that helps.
AC
geposted Sat 02 Apr 11 @ 12:37 pm
Go into "Config" then click on the "Options" tab, there youll see 3 sliders. I think the one you want is the first one. Let me know what your settings are after you find the spot yo want. I'm still trying to find that spot, lol!
Huey
EDIT> AC we gotta stop meeting like this, lmao!!
Huey
