Forum: Old versions
Topic: mac and pc registration- installing VDJ on 3 laptops
when i first registered my program, i used my pc laptop. that laptop died so i instaled it on a friend's laptop so i could continue djing. right now i just bought a brand new mac and tried to install the VDJ program but it wouldn't recognize the controller. is there any way for me to tell the program that the 1st laptop-- does not work anymore so that i could install the program on this new macbook pro?
i desperately need your help. thank you.
geposted Sat 02 Apr 11 @ 5:32 pm
the first laptop has no effect on you not being able to install on the mac. maybe there is a incomparability with your controller and the mac... you might need drivers for it
Please upgrade your DJ Console drivers and firmware to the latest version.
A link to download this can be found on the following page:
https://virtualdj.com/wiki/Common_Device_Drivers.html
Also, make sure that you have the latest VirtualDJ v7.0.3 installed: https://virtualdj.com/download/updates.html
NOTE: The End User License Agreement (EULA) allows you to have the software installed on up to two computers at any one time, providing that they are both for your own personal use and will not be used simultaneously (E.g: Second installation as a backup or for practising at home is OK, allowing a friend or another DJ to use it is NOT allowed.)
You may also uninstall the software from an old computer and then install it onto a new computer.
NOTE: If you intend to sell, give away or dispose of an old computer, you must remove VirtualDJ from it first.
You can download the install file for the software again (If needed) from the Download Center: https://virtualdj.com/download/updates.html
