Topic: All my kit that I want to get
this is the DJ equipment I plan to use as a bedroom DJ and at house party's ans small gigs. Do you think this sounds resemble to start off with.
Numark mix track pro
2 KRK Rokit RP8
3 GB Compaq laptop
Virtual DJ pro
Numark Red Wave Professional Mixing Headphones
not sure about amp or lights any recommendations greatly appreciated
geposted Sun 03 Apr 11 @ 11:53 am
Sounds good, the KRK speakers would be great for a bedroom or recording studio but for parties you need PA speakers, those are studio monitors- which means they're good at sounding great, but they won't be loud enough unless you just want background music in a small living room. If you want people to dance then you need PA speakers that will give you more volume.
As for lights, just get something cheap that projects some kind of moving shapes in all directions. Here's a good suggestion. The "Tri LED" stuff from american dj is pretty good.
http://www.htfr.com/p/349085/american_dj_vertigo_tri_led_led_moonflower
And make sure you buy a tripod stand to put it/them on so you can get them to ceiling height and have the lights shining down on people.
Hope that helps.
Thx great advice
I'll probably get two of these to start off with. if you think that would be enough for my whole light set-up (to begin with)
Which PA speakers should I get then?
No probs, cheers.
Speaker-wise, it depends what your budget is. If you're really tight you could even just buy one decent speaker to start with, then expand to a pair, basically you can spend anywhere from £200 to £1.200 for a single speaker.
Depends must be under £500 for pair because I don't have that kind of money and preferable with built in amp
Wow, I'm on a roll tonight...
http://cgi.ebay.co.uk/Mackie-SRM450-Active-Speakers-Pair-Monitor-DJ-Band-400W-/160565887446?pt=UK_ConElec_SpeakersPASystems_RL&hash=item25627901d6#ht_500wt_922
Try and squeeze that extra hundred quid out of your budget if you can, or keep your eye on ebay for more deals.
Mackie SRM 450 is kind of an industry standard but they're about 800-900 per pair brand new. Always go and listen to speakers to check they work properly if you're buying second hand!
If you want new then you'd have to make do with the more budget models. Not heard either of these, but I have heard from other people in the forum that they're very good for the price.
http://www.htfr.com/p/389325/mackie_thump_th12_a_400_watt_active_speaker
http://www.htfr.com/p/371105/mackie_thump_th15_a_400_watt_active_speaker
You'll get more bass out of the 15 inch ones than the cheaper 12 inch ones.
