Im using esi u46dj and i have problems with pops and cracks, and i have to exit virtual dj...
I use it in windows xp sp3 32 bits system... Asio driver seems that doesnt work ( when i click on setup asio nothing appears ( in the setup audio configuration), so i have to configure it with 2 sound cards.
Someone who use esi u46dj with virtualdj and windows xp... Which drivers do yo use ? 1.0.14, 1.0.16, 1.0.18... or the last 3.0 from 2009 ( http://download.esi-audio.com/?w=esi&p=26&g=2&l=en)
Any help would be apreciate....
Thanks in advance..
Thanks in advance..
geposted Sun 03 Apr 11 @ 5:28 pm
i would use the latest one the 3.0 and look underneath your sound card and look at the serial number if i remember correctly there was an issue with some sound cards.
btw what kind of problems u experiencing i have the u46 and tcv's and still rocking on strong for quite a while now..
pm me if u need assistance
rbhandhoo@gmail.com
rbhandhoo@gmail.com
geposted Mon 04 Apr 11 @ 10:49 pm
I have rev.B... as it only appears one sound device and one control panel in hardware elements.
Im using always the same usb port ( as i use a desktop pc). I have reinstalled many times drivers.... now i have 3.0 installed correctly. But as said before in vdj, when i go to setup audio .. i have:
Inputs: none
Output: External mixer
When i select asio driver.... then appears two possibilities: esi u46 and esiu46dj, both of them that i use when i click on the button of Config Asio....nothing happens...perhaps a problem with vdj and drivers..I also have unchecked the ultra-latency adio.
Which option do you use ? esi u46 or esi u46dj ?
Do you have ultra latency asio enabled ?
What latency do you have the driver set ( in control panel of windows not in vdj) ? 64, 128, 256, 288
Latency in vdj ? Auto, 64, 128...
Do you have Safe mode enabled ?
The 3.0 driver you use its from esi download page ? or did you get it from another source ?
And last... do you have windows xp sp3 with all updates... or what windows do you use ?
Thanks in advance...
Inputs: none
geposted Tue 05 Apr 11 @ 2:29 am
