Can I use my Mk2 as a soundcard for a set of CDJ's with timecoded cds and a mixer? Or do I need a different one like an Asio? I want to play mp3s off my computer and virtual dj and mix with the main mixer and cdj's. Essentially two RCA cables would go from the CDJs into the back of the Mk2 then into the mixer and the mk2 would be hooked up to my computer via usb correct? All the best!
geposted Sun 03 Apr 11 @ 10:02 pm
The sound card in the Hercules MK2 is 4-in/4-out ASIO capable, so can be used for timecode if you upgrade to the full VirtualDJ Pro at a discount: https://virtualdj.com/buy/
geposted Mon 04 Apr 11 @ 5:06 pm
