hey everyone, i was trying to see if anyone here knows how to disable sync, does the progam auto beatmatch by itself, cuz i have it on manual, but it still locks the beats together while i'm mixing, sometimes it messes up my flow so i'm trying to disable the auto sync
geposted Wed 06 Apr 11 @ 6:55 pm
Sounds like you might have BEATLOCK turned on, make sure that is off and see what happens.
Huey
Huey
geposted Wed 06 Apr 11 @ 6:57 pm
beatlock is off
geposted Wed 06 Apr 11 @ 7:06 pm
It's been my experience, that on some songs, for whatever reason, you simply Cannot turn off the beat lock. I run in to it occasionally on different songs and no matter how you set up your config, it still does it.
I think its simply one of those forever VDJ glitches.
geposted Tue 19 Jul 11 @ 7:09 pm
I disagree... It's probably smart play, it should be the lock near the play button, or you can map something to 'smart_play" to toggle it on/off
geposted Tue 19 Jul 11 @ 7:41 pm
