hi all
after uninstalled/reinstalling vdj (from instructions from VDJ support)..i've lost all my cues points and the complete database is unscanned.
I understood that the xml on the external (where i keep my videos/music), would hold all that info..which the xml is still there.
What other file is need for this information to come up correctly?
This is my laptop giving me this issues (which is VISTA)...i went to work last night and the desktop at work with VDJ recognized everything as normal (Complete cue intacted)...what file is this desktop looking at differently then my laptop.
thanks for any help.
im working tonight using my laptop and havent had a reply back from help support/email/phone
geposted Thu 07 Apr 11 @ 10:00 am
make sure that the file path is the same, I have never used vista, but when I upgraded to windows 7 from xp, they changed the filepath from "my documents" to "user" if you use find and replace on a "copy" of the xml file you could change the file path, again just make sure you have backed up you xml, you could accidentally corrupt the file you have
or you could use this
https://virtualdj.com/forums/144700/VirtualDJ_Plugins/Relocate_lost_files.html
geposted Fri 08 Apr 11 @ 12:53 am
thanks for the reply..i'll have to check into this, even though the files are showing up in the vdj browser, its just the additional info that isnt fixed.....
geposted Fri 08 Apr 11 @ 2:07 am
ah not sure then, but i don't think my internal hard drive and external have the same cue points for the same tracks... I would try to recover it from the normal hard drive if you can, not sure how to do it though.
geposted Fri 08 Apr 11 @ 2:10 am
i got everything back, (cue points/comments...etc).
i ran the registry tool, uninstalled VDJ, reinstalled VDJ...and now everything is back to normal...
https://virtualdj.com/addons/download/1/2170/Registry%20Tool.zip
geposted Sat 09 Apr 11 @ 4:32 pm
