Hi, I have recently been playing around with mapping my controller and was attempting to look at a .tif file for inspiration when it auto-opened and i guess tried to load?
Well now when I open VDJ i can see the icon on the taskbar but when I pan over it looks as though the skin is clear, and it wont open or maximize. Anyone know what I can do? Ive already tried reinstalling and it still wont open properly.
Thanks,
DJ_oNo
Thanks,
DJ_oNo
geposted Thu 07 Apr 11 @ 12:47 pm
I have the same problem. Did you by any chance find the solution?
geposted Tue 11 Oct 11 @ 8:28 pm
Sounds like you have corrupted or altered the skins tif fille.
Delete the damaged skin form the skins folder
re-download the damaged skin
it should now be ok
to edit or have a nose how the skins work, use skin creator for virtualdj :
https://virtualdj.com/addons/5990/Skin_Creator_Tool_-_Windows.html
it should now be ok
geposted Sat 15 Oct 11 @ 4:18 pm
