Is there any way to lock Virtual Folders in place?
I use a touch screen and it is really easy to accidentally drop one folder inside of another when I'm just trying to select it.
Thanks,
Tim
Thanks,
Tim
geposted Thu 07 Apr 11 @ 2:38 pm
I just used VDJ7 for the second event with my touchscreen system and the folder managment makes it nearly impossible to operate. Often, when I select a virtual folder it either moves it up and down the list or drops it inside another one. By the end of an event my folders are a mess!
Is anyone else out there using a touchscreen and having this problem? Any suggested work arounds?
geposted Mon 11 Apr 11 @ 2:13 am
How about editing the skin to make the folder text larger and easier to touch?
Keith
Keith
geposted Mon 11 Apr 11 @ 3:03 am
That is what I had to do, my fingers arent small enough!! lol
geposted Mon 11 Apr 11 @ 5:08 am
