When i load up asio driver its showing my 2 dn-s1200s twice. It shows
"DN-S1200_1
DN-S1200_1"
Not sure what could be the problem. Could I get some help please ? Thanks
"DN-S1200_1
DN-S1200_1"
geposted Thu 07 Apr 11 @ 6:12 pm
Well, i have a DN X1600 and it seems that Virtual DJ got some problems to open the ASIO driver in a correct way.
I can't help you exactly with your problem, but i'm able to say what i've done to correct my Problems. This schould correct your problem too.
Download the ASIO4ALL Driver and set up your device with that tool. You'll get a bit more latency but it solves every DN ASIO driver issue.
Don't forget to register your original Serial of VirtualDJ! otherwise it's not possible to give you another support!
C.Hackl
C.Hackl
geposted Fri 08 Apr 11 @ 1:58 am
