After unchecking the "Keep Aspect Ratio" option, it allows me to resize the window so that its easier to drag and drop files onto the decks. But is there a way to keep the window size permanent so that whenever I restart Virtual DJ, it comes up with the same size I did previously?
Im using VDJ 7 Pro b342.
Thanks
Thanks
geposted Fri 08 Apr 11 @ 6:41 am
No, i am afraid you cant. The dimensions of the video window are not included in the registries, so VirtualDJ can not remember your settings. This is something you could ask in the Wishes Forums.
geposted Fri 08 Apr 11 @ 11:11 am
