I know that I've done this before, but for the life of me I can't figure out how to do it again. What I want to do is put "Promo Only" or "8th Wonder" or whatever my video source to the album section of the tag without tagging each file. They are all in seperate folders i.e Promo only folder, 8th wonder folder.
Thanx in advance for any help
geposted Fri 08 Apr 11 @ 10:22 am
Try a third party software such as Media Monkey to do batch tagging. Make sure to rescan the tags in VDJ after to update the database.
Hope that helps.
AC
Hope that helps.
AC
geposted Fri 08 Apr 11 @ 4:38 pm
To do Video, the best method is if your ripping from PO or SP disc, is to use LMEXTRACTOR, once that is done use Sorenso Squeeze to convert to .mp4. After some time (depending on your hardware on your computer), use Tag & Rename to tag all the files. Works great and its worth the $30.00 (I believe that is what it cost to have a registered version). This has been the quickest method, trust me I have been doing this for about 6-7 years now and back in the begining it took a long time to rip from DVD.
geposted Fri 08 Apr 11 @ 6:24 pm
