Hello,
I was wondering if it is possible to use 2 pioneer cdj-400s to control all 6 decks, so I can have tunes (decks 1 & 2) playing at the same time, then use the 3rd deck to scratch on for example?
Thank you for your help!
Paddy
Paddy
geposted Sat 09 Apr 11 @ 6:02 am
Hi, yes it's definitely possible, you'd need to just find a spare button on the cdj to "switch decks".
There's a thread about what commands to use to switch decks somewhere I think. Hope that helps
geposted Sun 10 Apr 11 @ 1:35 am
No need to open multiple threads on the same subject Bro............. here's your other thread which was answered aswell, https://virtualdj.com/forums/146005/PC_Version_Technical_Support/Using_CDJ-400s_in_6_deck_setup.html
Huey
Huey
geposted Sun 10 Apr 11 @ 2:19 am
