Can someone help me out, I want to create a filter folder for the tracks that don't have the "KEY" in the ID3 TAG. Is this possible??
Thanks for the time
Huey
Thanks for the time
Huey
geposted Sat 09 Apr 11 @ 10:36 am
try 'key=0'
geposted Sat 09 Apr 11 @ 6:01 pm
isscanned=0 will give all the files that have no key as database field. No id3 tags infos there though. No batch process for key, bottom line, no !
geposted Sun 10 Apr 11 @ 1:12 pm
So you mean to tell me that I can make a filter folder that will find all songs with say "fat" in the title or filename but its not smart enough to tell me if the track has a "key" or not??? Really!
Huey
Huey
geposted Sun 10 Apr 11 @ 2:28 pm
I had a similar issue a few months back. Trying to set-up a filter folder for missing Genre. Ended up using Media Monkey to correct it since it has the ability to search out any missing ID3 tag info. It may work for key tags too.
It's a powerful tool and free! Totally worth the download.
AC
AC
geposted Sun 10 Apr 11 @ 11:35 pm
AC..i got a special filter for you. :)
Filter..
genre is ""
tell me if this works for you, to add it to the Filter examples wiki page
Filter..
genre is ""
geposted Mon 11 Apr 11 @ 9:29 am
BINGO!!!! We have a winner!!!! That worked perfectly djdad. Add it to the wiki
[djdad] Added. Thanks for the feedback :)
geposted Mon 11 Apr 11 @ 7:19 pm
