Forum: VirtualDJ Skins
Topic: [NEW] GHOST (O.S.D. Edition) - Page: 5
sorry to bump but how is the progress on the 1080 and 1280x800 resolutions going Phantom?
The 1920x1080 is almost ready...
The 1280x development is still in progress. Trying to shrink more all the graphics ain't easy... :(
Love this skin,
How could I mod the xml file so that when i playing a video on deck 3 (for filler) and my main audio on deck 1, when i switch from deck 3 to deck 1 video output goes blank because deck 1 only has audio. I want to be able to play my audio on deck 1 or 2 and my video on deck 3 or 4. This because i play a lot of old skool reggae that does not have music videos, so i use videos from concerts, shows with the same artist. Thanks for this great work of art.
djtaliban wrote :
Love this skin,
Any skin guru could help ?.
I'll have to check it out... I'll be back in a few days.
If you dont want the video to fade to black, goto Config->Video tab and uncheck the Fade to black on volume sliders.
The best way is to link those videos to your old school songs. Simply drag n drop the video files to the deck's window preview.
In case you need to use different videos each time, or to start those videos at different time point, then you need to use the volume sliders to mix and map the crossfader as video_crossfader. You will also need to map some keyboard or midi shortcuts as..
deck 3 leftvideo
deck 4 rightvideo
in case you need to have this setup whenever you start the software, you can add this line to the end of the xml (1 line before the </skin> line
<init action="deck 3 leftvideo & deck 4 rightvideo"/>
Soon:
The orange VU-meter means that limiter kicks in ;)
Absolutely love it George. Been using it for ages on our media PC. It is a Vaio LT2S with a very strange resolution of 1680x1050. Is there any easy way to get this skin to reasonably fit those sizes?
Keith
This version will be 1920x1080 but I think it can be resided down easy enough...
Nice job..
Shiny knobs!
Ooh errrrr.....
Demo of the VU/Limiter:
nice visuals George !
Thanks!!! I'm tweaking the VU's a little bit more... I'm metering the output to calibrate them, but I have to solve a few puzzles first :P
SEXY!!
Smokin Sexy!!!....ah....new term ;-)
Please include a 1600x900 resolution ;-)
Cheers,
Roy
