this is nice
geposted Thu 28 Apr 11 @ 6:30 pm
Any updates on the 1366x skin Phantom?
geposted Sat 30 Apr 11 @ 5:55 pm
Yes... Finally I managed to "shrink" everything without altering the wheels and some other vital graphic elements...
The browser area is a little bit smaller compared to 1440x version but it's still more than 50% of the screen (56.3% to be accurate)
All the graphics are ready now and what's left is the XML coding which should not take more than one or two days time to complete :)
geposted Tue 03 May 11 @ 3:23 am
Nice George! but i just tried to resize it to 1280 x 768 and it comes out 1280 x 900 (?) actually i think my resizer its buggin again...:-(
geposted Tue 03 May 11 @ 4:43 am
The resizer won't produce acceptable results with this particular skin since it uses a lot of custom graphic zones...
If you want to resize it down to 1280x perhaps you should wait a couple of days to get the 1366x version.
The 1366x version has NATIVE graphics, not resized ones ;)
geposted Tue 03 May 11 @ 5:44 am
yeah i know...just rushing a little...lol...
geposted Tue 03 May 11 @ 8:05 am
Excellent news Phantom! It may arrive in time for the weekend!!!!
Thanx for the update :)
geposted Tue 03 May 11 @ 7:25 pm
Hey! IMPORTANT!!! check this out!... I was lookin at Zanards X-24 (which he fixed the coding so you CAN resize it,you should look into that Phantom.)the swithched to the OCD that i had resized.I had dragged the X24 upwards too see something in the very bottom (hidden by my task bar) so when i opened the OCD it too was upwards and i could'nt access the configuration and maximize buttons ans couldnt drag it down.so i closed VDJ via the task Bar icon,then opened again and to my surprize the skin was the size i had chosen in order to fit (1270 x 758 ) since i according to the resizer program i could'nt make it less than 1280 x 900,and that 900 was'nt gonna work but its that the program is naming the skin wrong but it is resizing it! check it out ,if you have a 1280 x 800 or similar size screen.SOOO thats my report.I hope that helps some ,and hope Jeremk wont think I'm Slamming on his application,but there is some issues still....please Report back on this...you guys do Great work!
geposted Tue 03 May 11 @ 8:54 pm
??? Which update you mean ???
I'm waiting for the 1366 Version, too and hope, that this version will be uploaded until Thursday? The Skin looks very nice, but i have it to check with my resolution :-)
Always happy Djing!
geposted Wed 04 May 11 @ 1:31 am
1366 x 768 Native Screen Resolution
Graphics Composition Progress: 100% (Completed)
XML Coding Progress: 35%
The skin might be finished today...
geposted Wed 04 May 11 @ 4:10 am
This day is almost over for me...
XML Coding Progress: 92%
The skin should be ready tomorrow...
geposted Wed 04 May 11 @ 4:39 pm
Ghost O.S.D. 1366x768 (Native Screen Res)
Completed and available for download:
https://virtualdj.com/addons/13008/GHOST_O_S_D__Edition.html
Thank you very much for your support! :)
geposted Thu 05 May 11 @ 5:59 am
nice work Phantom. Can't wait to see what other resolutions you'll cook up :)
geposted Thu 05 May 11 @ 11:04 am
I will be testing it out this evening and will report back if I find any bugs. Looks great so far!
Thank you for your hard work sir.
geposted Thu 05 May 11 @ 6:13 pm
What other resolution(s) do you need?
geposted Fri 06 May 11 @ 1:12 am
well because when i resize to 1280x800 ,you have this weird little movement of the platters, and same for the 1366, and you know i don't want you resizing your skin because just one person asked
geposted Fri 06 May 11 @ 1:51 am
+1
1280X800
thx!!
edit.
1280X800
thx!!
edit.
geposted Fri 06 May 11 @ 1:55 am
I think he means 1280 x 800...
geposted Fri 06 May 11 @ 2:13 am
you're right
edit
geposted Fri 06 May 11 @ 2:42 am
Ok. I'll try to shrink it down to 1280X (800 & 1024)
However I can't guarantee that I'll be able to keep spinners the same size :(
They'll have to be a little bit smaller I'm afraid...
geposted Fri 06 May 11 @ 3:07 am
