Two issues with karaoke,
One, can anyone advise please, some of my Zipped MP3+G folders will play audio but not the video, I'd say about 80% of my karaoke files work, any idea's on a fix so they all play video
Two, The only way I have been able to change the key with out speeding up or slowing down the track is to use my mouse over the Key button and drag one way or the other, anyone know the shortcut keys to use, the num+ and Num - also change the speed, do not want to do that but rather just change the key, anyone have the cure?
Thanks
Thanks
geposted Mon 11 Apr 11 @ 9:39 pm
An old but useful link for karaoke files .. https://virtualdj.com/forums/100747/Music_Video_Discussion/Karaoke_Zip_Files_ERROR_-_Explanation_and_Solution.html?page=1
As for your shortcut try ..
key_move -1
and
key_move +1
key_move -1
and
key_move +1
geposted Mon 11 Apr 11 @ 10:10 pm
I just posted the exact thing here: https://virtualdj.com/forums/146103/General_Discussion/change_the_key_of_a_song_using_keyboard_.html
geposted Mon 11 Apr 11 @ 10:45 pm
Make sure that the files have been named correctly - The .ZIP file and the .MP3 and .CDG files contained within it must all have the same name, e.g:
ABBA - Dancing Queen (SF123-01).zip
|- ABBA - Dancing Queen (SF123-01).mp3
`- ABBA - Dancing Queen (SF123-01).cdg
If the CDG does not have exactly the same name, then VirtualDJ will not find it and will treat the MP3 as a normal audio file.
geposted Tue 12 Apr 11 @ 5:11 am
I've found that it doesn't matter if the zip file name is different, but certainly the cdg and mp3 contained inside have to match each other.
geposted Tue 12 Apr 11 @ 11:06 am
