Reaching out for some quick help here as we are about to make a purchase and could really use the insight and guidance.
**PC:
Intel® Core™ 2 or AMD Athlon™ X2
1280x1024 resolution
Multi-channel DirectX compatible soundcard (with inputs and outputs), recommended: Audio8DJ soundcard
1024MB RAM***
200MB free space on the internal hard drive with a 7200rpm drive speed
PSU is above 600w and has at least 2 12 volt rails
*** Suggest double to 2 GB of RAM
*** Suggest a 1TB (terabyte) external drive 7200rpm drive speed, which is both Mac or PC compatible for video/audio storage.
Additional requirements for Video mixing:
2048MB (2GB) RAM
ATI™ HD4850 (recommended) or NVIDIA® video card w/256MB of Dedicated DDR3 RAM
Video card must support dual-screen output
**MIXER:
Hercules DJ Console 4-MX DJ Controller: Comes with VDJ LE6, any idea of how much the out-of-the-box upgrade to Version 7 is?
How important is the soundcard on board the actual tower or PC if we are using the above mixer to process the sound?
Does anyone have a personal configuration that works flawlessly for you? Laptop vs. desktop?
Sure appreciate any feedback or help regarding this...
**PC:
1024MB RAM***
2048MB (2GB) RAM
**MIXER:
geposted Tue 12 Apr 11 @ 2:56 pm
The Hercules 4-Mx VirtualDJ LE is v7 because this controller supports 4 decks (VirtualDJ v6 only supports 2 decks.)
The upgrade price to the full VirtualDJ Pro is $149 instead of the normal full price of $299.
The Hercules 4-Mx has its own built-in DJ sound card, so the sound card in your computer itself is irrelevant.
geposted Wed 13 Apr 11 @ 11:40 am
