Just downloaded the update that virtual dj told me to download, "install_virtualdj_le_mixtrackpro_v7.0.3.msi". now my controller doesn't seem to be detected by vdj at all. I tried going into the setup menu and selecting it for input but clicking on input does nothing and the arrow next to input is also shaded out like it's not usable. Tried reinstalling the program from the disk and then reinstalling the update with the same problem. The normal program works but the special version I'm supposed to have apparently wont detect the controller it's made for. It wouldn't be a problem other than the fact that I have no way to adjust headphone volume using the version that came with the controller. Any help would be greatly appreciated!!
geposted Wed 13 Apr 11 @ 12:59 am
Yeah, I've had the same issue. I've searched everywhere to fix it/find a map that works but haven't had any luck. AND the LE version doesn't allow for custom mapping through the settings as far as I can tell, so we're kinda screwed. It'd be nice to get an update that has it mapped.
geposted Thu 14 Apr 11 @ 12:47 am
You're not alone, I have the same issue as well. Guess all we can do is wait for the mods to answer.
geposted Thu 14 Apr 11 @ 3:02 pm
