Hi all!
I was just wondering if somebody could tell me if this set up would work together before I buy all the equipment!
- 2 Stanton T.52B Turntables
- 1 Numark M2 Mixer
- 2 Rane Serato Scratch LIVE - Second Edition Control Vinyl Records
- Some sort of USB sound card, do I need one? I don't care about listening to the tracks while music is playing, I'm just wondering if one is necessary if I want to hear my music.. and would a cheap one like a Numark DJiO work?
- And of course Virtual DJ
If anyone could help me out here and tell me if all these equipment pieces would mesh together that would be GREAT!
Thanks!!!
- 1 Numark M2 Mixer
Thanks!!!
geposted Thu 14 Apr 11 @ 4:00 pm
That will all work if you purchase a soundcard that has inputs and outputs such as the NI Audio 8. VDJ will not work with an analogue system unless you purchase a soundcard that can turn it into a digital signal. There are plenty of timecode users that have set-ups such as this. Something like the DJ I/O doesn't support inputs from analogue units so you'll have to spend a bit more money on an audio interface.
geposted Thu 14 Apr 11 @ 4:11 pm
Thank you for your input. Would the Gemini IConnex work as a sound card?
geposted Thu 14 Apr 11 @ 4:28 pm
I don't believe so. I know very little about that model but it looks to be single input.
geposted Thu 14 Apr 11 @ 4:33 pm
A low budget sound card choice for timecode use, would be the Maya44USB.
geposted Thu 14 Apr 11 @ 8:50 pm
