I have had a chance to look at a number of controllers out there for under the said price range, and I have yet to see a better value. I am getting ready to acquire a secondary (backup) controller and the Mixtrack as of now appears the most sensible (in appearance and in build). Just the feel and touch of the platters alone are almost worth the retail price of entire device, imo. Keep in mind that this is a separate device from already possessing an audio interface within your deejay gear setup (for those looking for an all-in-one package, than at least one option is the "Mixtrack Pro" priced at more money). I currently prefer using a separate audio interface instead.
(One thing is for sure, if you transport this device a lot, I would recommend wrapping it up in a small blanket before putting inside a flimsy bag. One big thunk would probably, easily damage the plastic element(s) and/or weak metallic levers.)
If anyone knows of a better software controller for the approximate price point, please let me know. Feedback much appreciated (including web links for more information or other product options).
Thanks.
Thanks.
geposted Thu 14 Apr 11 @ 11:32 pm
IMO, the Mixtrack controllers are by far the best value in that price range. I have a mixtrack pro, easily the best $250 I've ever spent.
Good luck,
T
Good luck,
T
geposted Fri 15 Apr 11 @ 8:09 am
