low headphone output, I put this down to the crappie all in one controllers I was using however I recently bought the MP-X10 which is a mixer too so I expected not to have to struggle anymore. Wrong, it's still low!
What can I do? can I alter in settings somewhere?
PS,
It's not the headphones either.
PS,
geposted Fri 15 Apr 11 @ 10:35 am
You can use the function "headphone_gain" to increase the volume reference of the headphones in VirtualDJ.
(Some skins have a knob with this function)
geposted Sat 16 Apr 11 @ 5:02 am
is this the headphone volume knob? if so then i have this maxed.
if not then please explain so I can make the change.
geposted Sun 17 Apr 11 @ 2:17 am
Are you plugged into the CPU or into the mixer? I have the C3USB and it has a headphone plug. It can get so loud, I believe you will rip your head off. I've never had it above halfway.
geposted Sun 17 Apr 11 @ 7:50 pm
Did the headphone_gain work for you Charlie? I have a new vms4 with the same low headphone output. When I change the script for the headphone volume knob (headphone_gain +30) it has no affect - headphone output still low. I suspect this is controlled in the hardware as it doesnt matter what you put for the midi script, it has no effect on what the knob does. Ideas?
geposted Fri 08 Jul 11 @ 5:44 pm
