I was wonderin if the video effect TEXT if you could save a template so that you don't have to type it in every time you reopen VDJ. If so i would appreciate it if someone could explain it to me thanks. If not then I will have to mmake a visit to the Wishes Forum.LOL
geposted Sat 16 Apr 11 @ 12:59 am
If you don't see a save or load button then it's pretty safe to assume that you can't........ On another note you could just download them and check. If you can't do what you want then just delete it. Im pretty sure you can do it with Scotts scroll text plugin.
Hope that helps
Huey
Hope that helps
Huey
geposted Sat 16 Apr 11 @ 9:05 am
