Is there any way to change the Font in the TEXT Effect plug-in?
geposted Sat 16 Apr 11 @ 12:26 pm
yep in all of them, it will say font somewhere on the plugin.
geposted Sat 16 Apr 11 @ 2:50 pm
@Tayla How do you open the .dll file to edit it or change the font.. Are were do you change it at?
geposted Sat 16 Apr 11 @ 6:29 pm
Download the Text 2D plug-in. It has a few more options than the regular text plug-in. That should solve your problem.
geposted Sun 17 Apr 11 @ 3:05 am
@DJClint, I don\'t understand why you need to go into the .dll you can change the font and colour quite simply with the skin controls in all of the plugins usually.
This is the free Firetext plugin, (if your not using SMS to screen) just use it as a normal scroller for vertical or horizontal scrolling, single or multiple images to screen with pause/start, camera or outside source to screen, flash/movie files, use the template tab to save any set ups you want to use in the future.
Go here if you haven't all ready got it.... https://virtualdj.com/addons/10481/FireText_VirtualDJ_Plugin.html
geposted Sun 17 Apr 11 @ 4:08 am
Thank you Tayla I will use that for sure, I'm just trying to put stuff to screens but tiered of the plan text..
geposted Sun 17 Apr 11 @ 4:56 am
glad I could help, I'll try and make some new tutorials as soon as I can for you, give you some ideas you might want to use, just finding the time to do them is the problem... lol, there are some in the old Firetext thread in the plugin forum but they are a little dated now though.
geposted Sun 17 Apr 11 @ 5:21 am
