Forum: Old versions
Topic: American Audio VMS4 / LE
cnydjPRO InfinityMember since 2011
Am I missing something here. I had the demo / home version installed to see if I may like Virtual DJ before buying the VMS4 controller. It seemed ok. So I purchased the VMS4 which came with "LE" I un installed the old fre demo home version ond installed "LE" then the 20 day pro trial. What I am not seeing is the panel to set up a play list.... there is a big panel that lists songs as I search but I can not seem to put them into a list ready to play Also there seems to be no auto mix feature at all. and no beat match engin. Am I just not seeing these or what. Also if I was to buy the Pro7 version will if give me all the features as well as map to the VMS4
geposted Mon 18 Apr 11 @ 12:00 pm
geposted Mon 18 Apr 11 @ 12:06 pm
OK ... BUT if I pay the money and do the upgrade will I then get the missing "List panels" and the rest of the features or are they missing due to the VMS4 mapping.
geposted Mon 18 Apr 11 @ 12:09 pm
You will get ALL the Pro Full features. Free updates, free skins, effects, plugins etc etc.. :) No limits !
geposted Mon 18 Apr 11 @ 8:56 pm
i bought the vms4 and registered it for the pro version of virtual dj at ur profile at the virtualdj site , just type in ur serial number which is loacted under ur vms4 dj and thats it
geposted Thu 28 Jul 11 @ 9:10 am
VMS4 comes with VIrtualDJ LE (Limited Edition), not Pro - See http://www.virtualdj.com/products/comparison.html
It can be upgraded at a considerable discount to the full Pro by going to http://www.virtualdj.com/buy/index.html
If you have purchased or upgraded to the full Pro, then we would recommend that you register your Pro serial number on the page http://www.virtualdj.com/users/edit.html so that you can access all add-ons that you will be entitled to and download software updates when they are released in the future.
geposted Thu 28 Jul 11 @ 11:36 am
Ive recently bought a Macbook pro and it doesn't have a disc holder and i can't find my serial number anywhere to re-download Virtual DJ LE what shall i do?
geposted Thu 25 Dec 14 @ 12:44 pm
geposted Thu 25 Dec 14 @ 10:35 pm
