Does anyone have problems with the "I remote' connection?.It works for 20' and then I lose connection,it's scary when your are playing live because "VIRTUAL DJ" freezes for a minute or so.When I try to reconnect to the I pad ,VIRTUAL DJ does not recognize it.
any solution to this problem.
DJdtime.
DJdtime.
geposted Mon 18 Apr 11 @ 7:18 pm
I do not have a solution but, I do have a question. Are you noticing this phenomena more in one location, than another? There are "dead zones" where wireless connections are more sensitive to signal lose than others.
geposted Mon 18 Apr 11 @ 7:31 pm
Are you using a wirless router or Adhoc set up?
geposted Tue 19 Apr 11 @ 6:05 pm
Sounds like something is interfering with the wireless signal. Try changing the channel. Does the club own a microwave or cordless phone?
geposted Tue 19 Apr 11 @ 7:50 pm
