will my laptop support the ns7 with the following specs
Pentium dual core processor t4500 2.3 ghz
2 gigs of ram
windows 7 64bit
if more info is needed will post as needed. if so can someone please point me in the right direction if there is a link on how to install NS7 to work with Virtual dj or if you could tell me the steps on how it is done. but i would like to know more if my laptop has the specs to work with the NS7.
thanks in advanced
Charlie
2 gigs of ram
windows 7 64bit
thanks in advanced
Charlie
geposted Tue 19 Apr 11 @ 7:52 pm
I would not try it. Min Spec for a 64 bit OS with the NS7 is 2.4ghz processor and 4 gigs rams.
I have a 3.2ghz i5 with 8 gigs of ram and that is not even fast enough to get below 256 latency. So if you do try it, the response will have to be at eiter of the 2 slowest settings (512 or 1024) which is not very good if it works at all and produces useable sound. I ran into a ton of issues using a slower PC (close to your specs) and tore my hair out. Ended up building a crazy desktop I have to lug around everywhere. Hopefully, laptops will get to the specs I am currently at now, so I can down size. Till then, get a desktop if you want to run VDJ and the NS7.
You will thank me later, I tried 5 PCs before I came to this conclusion.
geposted Tue 19 Apr 11 @ 10:26 pm
Would you know if bring it down to a 32 bit Windows 7 would work and upgrading the memory as well to? Just saying cause ill be willing to do that lol
Thanks again for your assistance
Charlie
Charlie
geposted Wed 20 Apr 11 @ 12:30 pm
