I used to use smart_play in versions before 7 and found it very useful when mixing videos with very short intro/outros.
Since version 7 onwards smart_play on the left hand deck has never worked correctly. It will change the tempo to match the right hand deck, but, it will not matchup the beats. The right hand deck works fine. At first I thought it was a skin error until I tried it with the standard default skins and found that it is the same.
I use an Apple Macbook Pro i7 bootcamped with Windows 7. I also have VDJ installed on the Mac side and smart_play works fine on the Mac version.
Could the devs look into this please.
geposted Tue 19 Apr 11 @ 11:17 pm
