Under effects > activate > deck 1, I'd like to be able to specify which side I want my effects applied to with the press of two separate 'left' and 'right' buttons. Searched and couldn't come up with anything and after an hour of trying different combos I'm broke. Any ideas?
Thanks
-dxb
Thanks
-dxb
geposted Wed 20 Apr 11 @ 6:43 pm
just put deck # in front of your normal command.
deck 2 effect active etc etc
is that what you are asking?
geposted Thu 21 Apr 11 @ 1:47 am
or you can use "deck default" for any command and it will only effect the actively selected deck. If your using the left and right arrows map them as:
left
deck 1 select
right
deck 2 select
effect on/off
deck default effect active
I'm pretty sure that TAB is it default deck select button, If you just want to use that.
Finally you have the LE edition that does not allow mapping, so you need to upgrade to to pro to map this.
left
deck 1 select
right
deck 2 select
effect on/off
geposted Thu 21 Apr 11 @ 3:54 am
