Is there a serial number the Virtual DJ 7.0.3. Home Edition? I've just downloaded it from the Mac App Store, and it's great. But it annoys me that I can't download any plug-ins and stuff, because i'm not "registered"...
Anyone can help me?
Anyone can help me?
geposted Thu 21 Apr 11 @ 11:51 am
unfortunately in this world not much is free, VDJ is no different. In the home version you get to use the software to see if it is suitable for you to use, but to have access to all the features and the plugins you need to support the program developers by buying the software. You could buy it outright from this website, or if your serious about djing, the cheaper option is to but a midi controller with vdj LE then update your version to PRO, in the end you should save about $100 depending on what controller you buy.
If you want to see what features you have available go here, you can also buy it from there.
geposted Thu 21 Apr 11 @ 12:10 pm
Wow......you are annoyed that they have the nerve to ask you to pay for the software, so that you can have all the features, that their other paying clients have?
geposted Thu 21 Apr 11 @ 2:28 pm
As said, there is no 'serial number' for VDJ Home - it's a free version and as such plugins, skins and so on are not available from this site.
If you want addons you will need VDJ Professional which does indeed come with a serial number.
geposted Thu 21 Apr 11 @ 4:01 pm
Thanks for the answer synthet1c :)
geposted Fri 22 Apr 11 @ 2:58 am
