Hey there guys
im in the process of migrating my music over to a new lappy and i've tried to merge and alter the directorys of the DB xml file. i've come across a strange side affect of some of my tracks being listed twice. is there anyway to repair this as the fix clean button dont seem to remove the duplicate entrys. as a result my searchs are returning them
Any help appreciated
Matt
Matt
geposted Fri 22 Apr 11 @ 4:53 pm
Maybe the files are listed because they are realy there, check the location of the Dup. files by,
1. Go to browser right click on on "Field Header" and choose "Filepath".
2. Place an asterisk in the search box " * ".
3. Sort by Title field
4. See if those dups actually exist in different directories
5. Delete if you most any dut's.
6. If no dup's exist, then click on the "Fix" button in Browser Config. Panel..
7. ....Make sure you tranfered the Good db file to C:\Documents and Settings\XXXX\My Documents\VirtualDJ
8. If it's the external drive then it should be in the root directory E:\ VirtualDJ Database vX.xml or G:\VirtualDJ Database vX.xml.
Good Luck,
Joey....
Good Luck,
Joey....
geposted Fri 22 Apr 11 @ 9:07 pm
