Hey all, I've made a couple of playlists on virtual dj no worries, but I'd like to know if you can add songs to a playlist once it has already been saved? Or do you have to start making a new playlist? Thanks community
geposted Mon 25 Apr 11 @ 12:24 am
You certainly can! Open your playlist, add the new tracks and save it as a new playlist!
All the best.
AC
All the best.
AC
geposted Mon 25 Apr 11 @ 12:30 am
I tried to copy and paste songs from one playlist to another but that didnt work for me. How do I merge two playlists I have made together so it makes one playlist?
geposted Mon 25 Apr 11 @ 2:49 am
If you go to config and then choose options there is an option for AutoLoad Playlists, set that to smart. Now select your playlist from the folders menu on the left side of the browser and it will load it in the playlist panel on the right side. You can then add and remove songs from the playlist panel and save them accordingly.
Note: This option may not be available in the LE edition of the software as automix is not supported
geposted Mon 25 Apr 11 @ 5:32 am
