hey guys I need some inpute. I'm looking at the new Denon dn mc6000. I like that it's all in one, but i am concerned about it sound quality comparable to a Rane. what is this new controllers pluses and negatives any input would be great. I have the rane mp44, and the denon 2500 controller. I like to get any feedback good or bad on the new denon. Thanks everyone.
geposted Mon 25 Apr 11 @ 9:24 am
I mc 6000 is a great unit. I had a Rane mixer before and the sound quality is nice. I have run ecternal device off the Dennon and have been able to switch back and forth with out any problem. I run mine out to a set of QSC k12's. I had the VMS4 and the Mics were and are terrible. I mics on the 6000 sound crystal clear. You also have the effects built in. You won't be dissapointed in the dennon unit.
geposted Mon 25 Apr 11 @ 10:46 am
Sound quality on the MC6000 is excellent. Loads of headroom and crystal clear.
Had one working in a club since December and it's truly brilliant.
Keith
Keith
geposted Mon 25 Apr 11 @ 11:17 am
Indeed the 6000 is a fantastic controller/mixer I highly recommend it.
geposted Mon 25 Apr 11 @ 1:59 pm
alright so I bought the 6000 today! wow what a mixer. i have 5 gigs this weekend and im so excited to use it. I was told theres a fix out for the mixer volume being at 0 when you open vdj. somthing that has to do deleted in the mapper? im not really sure. are there any other tips or tricks i need to know about. thanks everyone for your input.
geposted Tue 26 Apr 11 @ 8:21 pm
I found tons of useful info on the DN MC6000 before and after purchasing mine at the link below. firmware, driver updates, mappers etc. I always noticed mics sound pretty bad on alot of the controllers with built in sound cards i.e. the Hercules RMX... The new Denon works great and sounds great too.
http://de.virtualdj.com/forums/138914/Hardware_Technical_Support/The_Denon_DN_MC6000.html?page=25
geposted Tue 26 Apr 11 @ 9:29 pm
