I just bought a Hercules Steel and was wondering what sound card would be best to use with it for cueing and previewing songs on a channel while a song is playing through the speakers on the other channel.
I use a laptop with Windows 7, 64-bit. I'm using Virtual DJ obv, and want a decent sound card that I can use for DJing small parties, nothing huge, but doesn't empty my bank account.
Thank you, any advice is appreciated!!
geposted Mon 25 Apr 11 @ 3:44 pm
Checkout Numark DJ IO or Native Instruments Audio 2 DJ those work good price are under $100 each depends where you buy...
geposted Mon 25 Apr 11 @ 11:47 pm
Thank you!
geposted Tue 26 Apr 11 @ 8:50 am
I use a ESI gigaprt HD and it work very well,that djio i had bad luck with it and got the ESI HD.
http://www.esi-audio.com/images/products/ghd.jpg
geposted Thu 28 Apr 11 @ 12:24 am
