Hi,
how to loop a complete track in VDJ - means: starting after end right from the beginning, seemless?
The loop function with max. 32 bars doesn't help me...-
Background: I've got musictracks, that are cut to loops exactly. They shall loop after playing 2-3 minutes seemlessly right from the beginning.
Is there any function / idea for it?
Thanks for support...
geposted Tue 26 Apr 11 @ 12:05 pm
just put the track in the playlist, set fade type, select repeat, and activate.
Rusty
Rusty
geposted Tue 26 Apr 11 @ 1:20 pm
thanks for the quick answer, i understand the idea.
but unfortunately it doesn't work: there is a little "hiccup" between end and new beginning, although the track is cut correct - without any empty space in it...
any other possibility to do "whole track loops" without using the playlists?
geposted Thu 28 Apr 11 @ 6:37 pm
