im noticing vdj is loading slower and slower. i click the vdj icon and it takes about 2 mins to open up. what are some things i can do to speed things up. im running windows 7 with no crap in it. 8 gigs of ram. and my c dirve is aobut half full. its got about 100 gig left unused. any ideas?
geposted Tue 26 Apr 11 @ 8:29 pm
When VDJ loads notice on which stage spends more time...loading database...loading skin...graphics engine, and report back.
geposted Tue 26 Apr 11 @ 10:15 pm
loading the data base seems to be the longest part
geposted Wed 27 Apr 11 @ 7:26 am
What is the size of your database xml file? Have you done a disc defragment recently? Try this too.. Config->Browser.. Select your HD C from the drop down list, and do Check, Clean , Fix with that order. Check may take some time though.
geposted Wed 27 Apr 11 @ 9:07 am
rid137,
did you resolve the issue? I'm having the same problem.
geposted Sat 21 Jan 12 @ 5:35 pm
