A past client called me and asked me if i could email him the music list of what i played at his wedding. lol where is that list kept and is it email-able?
geposted Tue 26 Apr 11 @ 10:40 pm
If you saved the playlist in the C:\Documents and Settings\My Documents\VirtualDJ\Playlists folder then you have a record of what you played. As far as emailing, sending them the playlist file will only do them good if they have VDJ so you may just just have to type it out.
geposted Wed 27 Apr 11 @ 12:48 am
Hello,
all music play are in the file Tracklisting
C:\Users\Philippe\Documents\VirtualDJ\Tracklisting
geposted Wed 27 Apr 11 @ 3:21 am
go to My Document, open VDJ, open playlist, scroll all the way to down to tracklisting, open tracklisting, scroll down to the dates you want to email, right click and highlight the songs for that date, left click and copy, then open notepad/wordpad and paste into that. Then just give it a name to save as. Now ready for emailing.
geposted Wed 27 Apr 11 @ 11:41 am
He's got to have all the song on he's CP for the log can read that all.
geposted Wed 27 Apr 11 @ 12:33 pm
All you need to do is,
1 Collect the songz you need to print in the browser.
2. You can also use a folder if you want.
3. Highlight all and drag to AutoMix PlayList.window.
4. Click on save option, name your playlist & click OK..
5. Open iTunes and click on any playlist.
6. Go to file, then library and choose "Import Playlist".
7. Go To: C:\Documents and Settings\ "Your Name"\My Documents\VirtualDJ\Playlists.
8. Find your playlist you saved in VDJ and import.
9. Once imported and highlighted.
10. Go to File, Print, and choose Song Listing, Click OK.
11. Now this will work only on selected media that is in iTunes..
12 If not you can always import into iTunes what is missing & Re-do above steps...
Good Luck,
Joey....
Good Luck,
Joey....
geposted Wed 27 Apr 11 @ 2:13 pm
I am curious as to why songs that i didnt actually play show up on this tracklisting. sometimes i load a song but decide not to play it, but it still shows up. any idea why this is the case and is there any way to stop this from happening aside from my only loading songs that i plan to actually play. thanks.
geposted Sat 30 Apr 11 @ 10:38 am
