I want so setup my VMS4 so my turntables control decks 1 and 2, 3 and 4 on the VMS4. Does anybody have a map for this? And also, how would the sound settings look like under advanced config? I have not been able to get sound out of Ch. 3 and 4 but I was able to get Ch.3 and 4 to come out on Ch. 1 and 2 but that defeats the purpose 4 Chs and 4 decks
geposted Wed 27 Apr 11 @ 3:09 pm
Sorry, this is not possible in VirtualDJ LE.
You will need to upgrade to the full VirtualDJ Professional at a considerable discount to be able to use 4 decks and the custom mappings that make this possible: https://virtualdj.com/buy/
Once you have upgraded, 4 deck mappings can be downloaded from https://virtualdj.com/addons/controllers.html?category=best&order=default&search=vms4
geposted Thu 28 Apr 11 @ 5:43 am
I did all that but hve no audio on decks 3 and 4 help me please.
geposted Thu 28 Apr 11 @ 2:11 pm
I am a VDJ 7 Pro user.. if I buy a VMS4, can I use it to control deck 1&2 with CDJ 800's and time code and Decks 3 & 4 with the platters on the VMS4? can I use just the VMS4, CDJ800's (w/timeode) and VDJ PRO 7?
geposted Wed 11 Jan 12 @ 8:21 am
im having the same problem and i have vdj pro
geposted Wed 11 Jan 12 @ 10:05 pm
hey can someone fix this issue? I am having the same problem, I have 2 turntables and would like to utilize the 2 VMS4 decks along with them, so turntables on decks 2&3 and VMS4 on 1&4, something like that, but I cant figure out the configuration. if this isnt possible I might sell the VMS4...
geposted Sat 04 Feb 12 @ 9:07 pm
