I put the DM 6000 a couple of days ago and two channel mode have not had any glitches. But I stumbled across a serious glitch in four channel mode it was hoping somebody might have a fix to it. I'm sure the problems not the caused by my laptop. I have tweaked my PC as per the virtual DJ tweaks report. Of running Windows 7 ultimate, with nothing else installed on the computer. It for deck mode, using deck three or four and while a song is playing move the knob above the second FX button, causes my system the stutter freeze momentarily then stutter a few more times and then will continue to play. This issue does not have been waiting to deck mode. I'm using the updated firmware from Denon. Does anybody know of this issue or causes and in the tweaks to fix it
geposted Thu 28 Apr 11 @ 11:10 pm
Sounds like you are enabling the Beat Grid Effect. Check your effects and see if you get the same stutter when using this effect.
geposted Sun 15 May 11 @ 12:47 pm
Hi,
I am new to VDJ and am also using a Denon 6000. I too am experiencing the left deck (only) stuttering and then re-starting. I am trying the suggestion around Beat Grid but can't seem to find this in the Config Options?
Can you also please point me to the VDJ Tweaks report referred to in the first post so I can optimise me PC effectively?
Many thanks.
Many thanks.
geposted Mon 16 May 11 @ 4:46 pm
