To whom it may concern,
I recently purchased a Numark Mixtrack (Not a Pro) just a standard Numark Mixtrack. I want to start DJ-ing at parties etc. The only thing is that, the standard Numark Mixtrack doesn't have a Soundcard in it so I can't plug in my headphones, speakers etc.
If I want to do start DJ-ing at parties, then how am I going to do this?
Also I need speakers as well.
If you could reply ASAP, it would be greatly appreciated.
Cheers
Johnny.
Cheers
Johnny.
geposted Fri 29 Apr 11 @ 7:00 am
You will have to purchase a usb sound card, use the laptop build in soundcard to your amplifier and connect your headset to the usb card, then config virtualdj for "headphones / 2 card".
geposted Fri 29 Apr 11 @ 7:31 am
http://www.turtlebeach.com/products/sound-cards/audio-advantage-amigo-ii.aspx
this is very good and inexpensive USB sound card. I carry 2 or 3 for backup.
Good luck,
T
Good luck,
T
geposted Fri 29 Apr 11 @ 9:39 am
get something like the audio 2 dj for the soundcard and speakers i think this will do the job and it is very good but it is £80
geposted Fri 29 Apr 11 @ 4:23 pm
Good luck,
T
THANK YOU GUYS SO MUCH FOR CONTRIBUTING!
I will go and buy one soon :)
Thank you again
<3
Good luck,
T
Thank you again
<3
geposted Fri 29 Apr 11 @ 9:08 pm
