hI, recently i bought the following gears:
Pioneer CDJ800mk2 (1 pair)
Pioneer DJM 700
MacBook 4,1 undibody
Pioneer HDJ500
Anyway, here is my question.
Are these gears enough for me to start mixing? can i connect the CDJs to the macbook directly, or do i need an external soundcard? a m-audio connectiv torq?
im already running low on budget so instead of an m-audio, a friend suggested a behringer uca200. if that would be my option, do i need two pieces or uca200 or just 1?
or do i need a uca200 at all? maybe i can connect my DJM and CDJ to the macbook directly using a midi cable?
i am confused. can anyone make me a diagram? i definitely can not afford a SERATO LIVE yet.
Thank you
Pioneer DJM 700
Pioneer HDJ500
Thank you
geposted Sun 01 May 11 @ 4:07 pm
To use VDJ you will have to get those things:
* Timecode CDs (fo free download if you got a VDJ pro version)
* VDJ Pro FULL
* Soundcard (4 ins 4 outs)
this is minimal equipment you need to get the CDJs 800 mk2 to work with VDJ. Otherwise it's better to burn you songs to CDs and use the analog equipment without Laptop.
* VDJ Pro FULL
geposted Mon 02 May 11 @ 5:25 am
